Sony MZ-RH10 - Power Failure ?
Hey All,
Has anyone experienced this:
I was recording a live event on the Sony MZ-RH10, I took out the battery and plugged it into the wall charger. It was recording all of a sudden, the power turned off, the lights and everything.
I turned it on, started again, boom, same thing..... It did not record anything, over 5hr+ of audio gone.
Any idea why that happend ? If so, solutions ?
Minidisc has to write the table of contents for the disc to be read. If any power gets cut off then it won't be recorded, unless you have the battery inside.
Interestingly there is a professional marantz portable that automatically creates the TOC as you record audio to protect against this very thing from happening.
