Problem: Unable to transfer songs in ATRAC format to HD5
freebird2003
Hello,
i juz bought NW-HD5. At the moment i am trying to learn how to use. all my songs are in mp3s. i am trying to transfer the songs in atrac format using sonicstage 3.4 but i am getting error message. When i click the tranfers button in sonicstage, a error message appears saying transfers not allowed. but under the transfer mode setting, when i click standard transfer mode, i am able to transfer the song to ND5 but in mp3 format.
please help me. :unsure:
thanks alot
7 answers to this question
Guest Stuge
Format your HD5 Hard Disk using main menu of HD5 First ..
Alos are you able to convert those Mp3 files to Atrac manually .
convert MP3 to Atrac
1.IN MY library of Sonin Stage
2.Select a file which you want to convert .
3.Right click on the file =>Then click on Convert ..then convert the file in the bit rate you like ..
when i try to convert the mp3 track from the music library i get this error message. it is very anoying. i don't know what is happening. actually i have tried unistalling ss 3.4 and install ss 3.3 but still the same error msg. plz help
thanks alot.
Edited by freebird2003
Guest Stuge
I also having this problem with about 200 mp3 files .I can`t convert them to Atrac .I was able to convert those files to Atrac USING SSver3.0 .
But YOU can convert those track First convert those .mp3 files to .wav then import them into SonicStage .Then convert them to Atrac. .It is bug in SonicStage ver3.3 & up
i have abt 2000 plus mp3. how am i supposed to transfer them to my hd5 in atrac. every songs is not able to convert. this is very strange and anoying. i even try to install ss 3.1 that came with HD5 but the same problems happends. i even try to use viao music transfer. it transfers and atrac but when i look at the screen of hd5, the format is mp3 at 128 kps. is there anything wrong with the device ?
plz help me thanks
Guest Stuge
  freebird2003 said:
i simply can't understand why it can't convert. i am getting very fustrated. :(
I understand what you are feeling & Even I have no answer to this question ..
WHy don`t you convert one of your tracks to .wav then convert it to Atrac (just see what happens ).
i juz did an expirement. i juz want to know wat is the problem. at the moment i have nothing to lose expect time. since i have backup my programs and songs. i reformated my comp and install all my nessesary apps. than i install sonicstage 3.4 after reboot, i start the sonicstage 3.4 program. i juz pick a song from my drive and tried to convert to atrac format. the same error msg came. "cannot convert the specific Track Blah Blah Blah" i juz don't know wat is the problem. i downloaded the ss3.4 web installer from sony ap site. now i am thinking should i get the ss3.4 from other region sites.
i tried to look into the cd that came with my HD5. it contain some setup reg programs in the common folder and sonicstage folder. i am wondering, does the sonicstage requires some reg setup files to be install inorder songs to be converted to atrac format ? i juz wrote and email to sony abt the problem that i am having. juz crossing my fingers. they have not reply yet. i hope they will give me a solution.
:unsure::unsure::unsure:
