MS702 Read Trouble
dading
hi! i recently buy a sharp 702 that doesn't read, i was trying to solve the troubles but it seem a eeprom trouble, y tested the laser on a sr50 and worked fine, when i go to the autocalibration y the test menu y says "ADJ OK" in both calibratiosn and the autoplay test run smoothly nad perfect, but when y try to play a disc in normal mode it can't read, stays trying and tryin and trying and nothing happened, if somebody can hive a little help with eepros to check or has solved a similar trouble y say thanks in advance. Greeting to everybody!
