AT3 conversion error
zappalaterra
I have a soundtrack in AT3 format and wanted to convert it to WAV/MP3.
Installed latest SonicStage 4.3 and HIMDRenderer 0.54.
I could convert all the titles, but one, successfully.
The offending file from the same soundtrack, produces the error:
ERROR:[1830-3-0]: Failed to connect to a Sony OMG/OMA filter
heres the log:
e:\users\Rix\Desktop\himdrenderer054\Log0.log
New Log File 11/09/2008 20:41:52
11/09/2008 20:41:58.181 : 0x15BC : PCM .WAV File
11/09/2008 20:42:01.347 : 0x14C0 : DoWork: Types left to try: 3.. Retry enabled:1  Current Type:3
11/09/2008 20:42:01.347 : 0x14C0 : InitCore
11/09/2008 20:42:01.347 : 0x14C0 : DoWork : AT3 file - tmpfile=[e:\users\Rix\Desktop\himdrenderer054\tmp.oma]. Src=[e:\users\Rix\Desktop\Vice\VCPR.AT3]
11/09/2008 20:42:02.689 : 0x14C0 : InitSmpData:
11/09/2008 20:42:02.689 : 0x14C0 : InitSmpData: create event
11/09/2008 20:42:02.689 : 0x14C0 : InitSmpData: reset event
11/09/2008 20:42:02.689 : 0x14C0 : InitSmpData: init stuff
11/09/2008 20:42:02.689 : 0x14C0 : InitSmpData: init structures
11/09/2008 20:42:02.689 : 0x14C0 : InitSmpData: init CS
11/09/2008 20:42:02.689 : 0x14C0 : DoCoreConversion: from[e:\users\Rix\Desktop\himdrenderer054\tmp.oma] to [e:\users\Rix\Desktop\Vice\VCPR.AT3.wav]. Tag:1
11/09/2008 20:42:02.689 : 0x14C0 : Using simple OMA directshow (OMA2)
11/09/2008 20:42:02.689 : 0x14C0 : creating OMA objects
11/09/2008 20:42:02.689 : 0x14C0 : Create Graph
11/09/2008 20:42:02.689 : 0x14C0 : Create filter graph --
11/09/2008 20:42:02.689 : 0x14C0 : Error: Unknown error 0x800401f0 [CO_E_NOTINITIALIZED]
11/09/2008 20:42:02.689 : 0x14C0 : Retry Create filter graph
11/09/2008 20:42:02.689 : 0x14C0 : Success !
11/09/2008 20:42:02.689 : 0x14C0 : Create source
11/09/2008 20:42:02.689 : 0x14C0 : add omgsoruce to graph
11/09/2008 20:42:02.689 : 0x14C0 : Get omgsrc_base output pin
11/09/2008 20:42:02.689 : 0x14C0 : Release: ienummt [0x1c26288]
11/09/2008 20:42:02.689 : 0x14C0 : Release: enumpins [0x3a11160]
11/09/2008 20:42:02.689 : 0x14C0 : omgsrc_output:[fixedsamples:1] [temporal compression:0] [format info size:0] [sample size:1]
11/09/2008 20:42:02.689 : 0x14C0 : omgsrc_output majortype :: 0xe436eb83 0x524f 0x11ce 0x9f 0x53 0x00 0x20 0xaf 0x0b 0xa7 0x70
11/09/2008 20:42:02.689 : 0x14C0 : omgsrc_output subtype :: 0x0839f6ac 0x86ba 0x4f6e 0xaa 0xa6 0xb2 0x2b 0x76 0x7a 0x4e 0x23
11/09/2008 20:42:02.689 : 0x14C0 : omgsrc_output formattype :: 0x00000000 0x0000 0x0000 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
11/09/2008 20:42:02.689 : 0x14C0 : omgsrc_output format data : NO DATA
11/09/2008 20:42:02.689 : 0x14C0 : Create transform
11/09/2008 20:42:02.689 : 0x14C0 : Create OMA TRANSFORM for oma file
11/09/2008 20:42:02.705 : 0x14C0 : Success !
11/09/2008 20:42:02.705 : 0x14C0 : Add OMA TRANSFORM to graph
11/09/2008 20:42:02.705 : 0x14C0 : get input in from oma trans
11/09/2008 20:42:02.705 : 0x14C0 : Connect source - > transform
11/09/2008 20:42:02.705 : 0x14C0 : Connecting *DIRECTLY* src To omg transform
11/09/2008 20:42:02.736 : 0x14C0 : Error: Unknown error 0x80040207 [DIERR_NOTBUFFERED]
11/09/2008 20:42:02.736 : 0x14C0 : Failed to *directly* connect - trying indirect method:
11/09/2008 20:42:02.767 : 0x14C0 : Error: Unknown error 0x80040217 [Unknown]
11/09/2008 20:42:02.767 : 0x14C0 : CloseDShowInput: disconnecting omg / oma pins (1)
11/09/2008 20:42:02.767 : 0x14C0 : CloseDShowInput: disconnecting omg / oma pins (2)
11/09/2008 20:42:02.767 : 0x14C0 : CloseDShowInput: Loading null file to relase file
11/09/2008 20:42:02.829 : 0x14C0 : CloseDShowInput: done
11/09/2008 20:42:03.095 : 0x14C0 : DeinitCore
