soulphonique Posted January 14, 2009 Report Share Posted January 14, 2009 (edited) help needed guys....sonicstage 4.3 cp not working on my winxp sp3 although version 4.0 works perfectly....got an error msg.:"cannot locate needed files related to Windows Media Format. Exiting sonicstage (error code: 0004e22)"....besides link for ver4.0 dwnld from this forum "http://forums.minidisc.org/downloads/details.php?file=21" is not working....thx 4 your helping posts..pentium m 1,7GHz1GB RAM Edited January 14, 2009 by soulphonique Quote Link to comment Share on other sites More sharing options...
raintheory Posted January 14, 2009 Report Share Posted January 14, 2009 4.2 is yr best bet if you can find it. Many ppl have reported problems with 4.3 on anything other than Vista. Quote Link to comment Share on other sites More sharing options...
soulphonique Posted January 14, 2009 Author Report Share Posted January 14, 2009 4.2 is yr best bet if you can find it. Many ppl have reported problems with 4.3 on anything other than Vista.okay....maybe someone could help me find ver4.2 or fix the link to ver4.0 on this forum´s site..huh.? Quote Link to comment Share on other sites More sharing options...
raintheory Posted January 15, 2009 Report Share Posted January 15, 2009 (edited) I've uploaded the full 4.2 here for the time being: http://drop.io/4eod1htYou'd do best to completely delete 4.3 (including registry entries if you are comfortable finding and deleting them).Before you do so, be sure to back up anything you have in SonicStage...1. Uninstall 4.3 via add/remove programs2. Delete the following folders: "Documents and Settings/All Users/Application Data/Sony Corporation/Sonicstage" "Documents and Settings/All Users/Sonicstage" "Program Files/Common Files/Sony Shared" "Program Files/Sony/Sonicstage" "Program Files/Sony/Personal Audio Driver"3. Delete the following registry keys: 'HKEY_CURRENT_USER/Software/Sony Corporation/Sonicstage' 'HKEY_LOCAL_MACHINE/Software/Sony Corporation'4. Make sure your AntiVirus is temporarily disabled, and reinstall using 4.2 5. Enjoy!-AaronEDIT: The installer was grabbed from this site awhile ago, but to be safe there are various online single-file virus scanners available if you would like to scan the file for viruses prior to installing. I know disabling antivirus can be nerve-racking. ...Alternately you can just point yr antivirus to the downloaded file prior to disabling it to install...EDIT 2: If you still encounter the issue, perhaps try reinstalling/upgrading Windows Media Player? Edited January 15, 2009 by raintheory Quote Link to comment Share on other sites More sharing options...
soulphonique Posted January 17, 2009 Author Report Share Posted January 17, 2009 I've uploaded the full 4.2 here for the time being: http://drop.io/4eod1htYou'd do best to completely delete 4.3 (including registry entries if you are comfortable finding and deleting them).Before you do so, be sure to back up anything you have in SonicStage...1. Uninstall 4.3 via add/remove programs2. Delete the following folders: "Documents and Settings/All Users/Application Data/Sony Corporation/Sonicstage" "Documents and Settings/All Users/Sonicstage" "Program Files/Common Files/Sony Shared" "Program Files/Sony/Sonicstage" "Program Files/Sony/Personal Audio Driver"3. Delete the following registry keys: 'HKEY_CURRENT_USER/Software/Sony Corporation/Sonicstage' 'HKEY_LOCAL_MACHINE/Software/Sony Corporation'4. Make sure your AntiVirus is temporarily disabled, and reinstall using 4.2 5. Enjoy!-AaronEDIT: The installer was grabbed from this site awhile ago, but to be safe there are various online single-file virus scanners available if you would like to scan the file for viruses prior to installing. I know disabling antivirus can be nerve-racking. ...Alternately you can just point yr antivirus to the downloaded file prior to disabling it to install...EDIT 2: If you still encounter the issue, perhaps try reinstalling/upgrading Windows Media Player?thanx man....but.:the installer is somehow corrupted..it can´t install openmg..after rebootin´ installer is tryin´ 2 finish the installation of openmg and wants me to manually find the "OpenMG Secure Module.msi"..tried usin´ different copy of that file but doesn´t work. Quote Link to comment Share on other sites More sharing options...
