DaveNH700 Posted February 22, 2009 Report Share Posted February 22, 2009 Hi all,I recently downloaded and installed SonicStage4.3 from the Sony website to my laptop. When I connect my MZ-NH700 MD walkman it is recognised and allows me to control it and transfer to/from it no problem. But when I connect my MDS-JE780 NetMD deck SonicStage doesn't seem aware of it at all. Windows recognises that a device has been connected but not SonicStage. I've made sure the JE780 deck is in NetMD mode but it doesn't see it in SonicStage.Any ideas why this could be? Should I be using an older version of SonicStage to be compatable with the 780 deck?Any advice much appreciated,Thanks,Dave. Quote Link to comment Share on other sites More sharing options...
Avrin Posted February 23, 2009 Report Share Posted February 23, 2009 (edited) This may seem outrageously stupid, but SONY have removed Plug and Play identifiers for decks from their driver packages some time ago. The actual identifiers that have been removed are USB\VID_054C&PID_0080 and USB\VID_054C&PID_0081. The current NETMDUSB.sys driver file should work with decks, but it won't, because the required identifiers are missing from its INF installation file.You need older drivers. Get them here: http://forums.minidisc.org/downloads/download.php?file=62 - they work with SonicStage and MDS-JE780. Edited February 23, 2009 by Avrin Quote Link to comment Share on other sites More sharing options...
DaveNH700 Posted February 25, 2009 Author Report Share Posted February 25, 2009 - Many thanks, I shall try installing these drivers tonight.Dave. Quote Link to comment Share on other sites More sharing options...
DaveNH700 Posted February 25, 2009 Author Report Share Posted February 25, 2009 - Just downloaded and installed them, works a treat.Thanks,Dave.This may seem outrageously stupid, but SONY have removed Plug and Play identifiers for decks from their driver packages some time ago. The actual identifiers that have been removed are USB\VID_054C&PID_0080 and USB\VID_054C&PID_0081. The current NETMDUSB.sys driver file should work with decks, but it won't, because the required identifiers are missing from its INF installation file.You need older drivers. Get them here: http://forums.minidisc.org/downloads/download.php?file=62 - they work with SonicStage and MDS-JE780. Quote Link to comment Share on other sites More sharing options...
