Mike Parker Posted March 6, 2009 Report Share Posted March 6, 2009 Hi everyone"Sorry if this isn't the spot to post questions. I didn't see another spot for my question.I've inherited a Sony MZ-NF810 recorder but can't seem to make it work properly. I think it is recording but it doesn't seem to play back. I don't have the original earphones with the remote and instead I'm using a regular pair of ear buds from the Dollar Store. Do I need the original earphones?Any help you could suggest would be great. I also need help setting or confirming the settings and basically "making it go". Thanks!Mike Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted March 6, 2009 Report Share Posted March 6, 2009 Well, you don't need the original earbuds, any ones with a 3.5 mm jack would do. A few questions would help point to the problem if there is one:- How exactly are you recording? Microphone, line in, optical in or via PC with Sonictsage/Simpleburner?- What connectors to your source (CD, cassette, microphone) are you using?- Does the recording level bar in the MD display window fluctuate when recording?- Have you tried the radio - does that work?- If you access to a pre-recorded MD, does that play back OK?Can't think of any others for the moment, but that should hep. Quote Link to comment Share on other sites More sharing options...
Mike Parker Posted March 6, 2009 Author Report Share Posted March 6, 2009 Well, you don't need the original earbuds, any ones with a 3.5 mm jack would do. A few questions would help point to the problem if there is one:- How exactly are you recording? Microphone, line in, optical in or via PC with Sonictsage/Simpleburner?- What connectors to your source (CD, cassette, microphone) are you using?- Does the recording level bar in the MD display window fluctuate when recording?- Have you tried the radio - does that work?- If you access to a pre-recorded MD, does that play back OK?Can't think of any others for the moment, but that should hep.Hi Barock:Thanks for the reply. I'm recording using a microphone (mic in), with a Shure SM 58 mic and standard cable.The recording bar does flucate when recording. But I haven't tried the radio as I do not have the remote and can't find the settings on the recorder itself.Oddly enough, it does play pre-recorded MDs.I'm suspecting bad play heads as per the reply in the above thread (see forum). Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted March 7, 2009 Report Share Posted March 7, 2009 Yes, judging by that thread, your overwrite head may have gone. Could still use it as a player, but it would be uneconomical to have it fixed. I imagine the radio would work, you may be able to find one on eBay. Quote Link to comment Share on other sites More sharing options...
