MZ-RH1 accesories
gujarati
I just acquired a MZ-M200 with no accessories. I separately ordered LIP-4WM's.
I have never ever been a remote user on minidiscs. I am not sure if I will need one for RH1. I have remotes from MZ-N707, N510, R50, E80. Would these remotes work? If not what's the best remote to get.
I would not need a mic. And for charging/tranferring, can I just use the usb cable that comes with netmd recorders?
Edited by gujarati
Try your newest remote, like the MZN707, and see how it works.
The RM-MC40ELK remote is mighty nice--it has a recording level indicator and a backlight (though using the backlight while recording makes a little bit of static). The RH1/M200 remote is really made to work with the unit like another line of the display--look at some of the pictorials that were posted here with the RH1 was introduced--but finding one might be difficult.
