Conversion to WMA/MP3/etc. via Sound Forge 8.0d
hpmoon
So far there is no path for directly converting ATRAC files into WMA files. Many situations exist today where WMA is the only option, either because: (1) you choose a lower bitrate such as 64 kbps because of flash player space limitations, and WMA is the only game in town (vs. MP3 which is indisputably inferior at 64 kbps); or (2) WMA is the only supported file type (e.g., all Verizon mobile phones with digital music capability).
Currently, the quickest way to do this is to use Hi-MD Renderer for a batch convert to MP3, retaining metadata, and then transcoding those MP3s into WMAs. Obviously, that's a lossy thing to do to already very lossy files.
There's hope on the horizon, but like always, Sony almost gets us there but not quite. With the release of Sound Forge 8.0d, Sony added support for importing all kinds of ATRAC files, including ATRAC Lossless, which can then be saved to whatever format you like among Sony's impressive list of codecs -- including WMA, and even WMA Professional (though we're still waiting on access to the Holy Grail of low-bitrate codecs, WMA Professional Plus, which is what Verizon uses for delivering music over its network). Sony also added a fantastic "Batch Converter..." option (under the "Tools" menu) that can take nested folders of media files (e.g., SonicStage's "My Library"), perform operations such as conversions to WMA format (as well as additional conversions to MP3, etc. during the same pass!), and then store the converted files into separate folders that match the folder structure of the originals.
But surprise, surprise -- while you can "Open..." an ATRAC file in the same application, you can batch convert every other kind of source file except ATRAC Lossless. Since Sony spilled the beans by allowing ATRAC Lossless imports anyway, its exclusion from the Batch Converter is more likely a bug, but with Sony, you never know...
Anyway, please go to this link to encourage Sony to add ATRAC Lossless processing ability to the Batch Converter. With this addition, a whole new world of options will open up for ATRAC users. I personally don't have much of a problem having Sony's suite of software consist of components to tackle "pro" tasks versus. consumer tasks -- a big chunk of the criticism about SonicStage goes away when this Batch Converter gets its wings.
Edited by hpmoon
As a follow-up to this discovery on performing a batch conversion directly from ATRAC formats into WMA/MP3/etc., I've found a semi-automated way to make this work. Unfortunately, this technique is limited by your computer's processing power and memory capacity. I was successful with this procedure opening several dozens of files on a Pentium IV/3.0 GHz/2gb RAM PC. With all due respect to Hi-MD Renderer, this has become the best possible way to convert files from "My Library."
1. Open all the ATRAC files that you want to Batch Convert, from within Sound Forge 8.0d. You can do this by going to "File" then "Open...", then selecting multiple items (or all the files) in a folder. Before moving on to Step 2, you can open additional files from other folders by repeating this step.
2. There will be a delay while waiting to load the ATRAC files, due to Sound Forge's automatic peaks-building algorithm -- it will do this for each file that opens, each in its own window. Just wait for them to finish. If you don't want to deal with a bunch of .sfk files after these peaks are built, make sure that you select "Delete temporary files on close" within "Options" then "Preferences..."
3. Go to "Tools" then "Batch Converter..." and you will see all the ATRAC files you opened in the list, as demonstrated below.
4. Click the "Save" tab (see example in the picture attached to the first post in this thread). Click the "Add Save Options..." button. Select your codec (e.g., WMA, MP3, OGG, WAV, etc.) and fine-tune it as desired. When you specify the destination directory, you can "Preserve source subfolders" by checking its box. Note that you can add additional save options to this tab's list for concurrent transcoding of a single source to multiple files (e.g., OMA --> MP3 and WMA).
5. Click the "Run Job" button on the bottom right. You'll see the progress under the "Status" tab.
6. Upon completion, you can easily close all the open files/waveforms as indicated below.
