hardhousehead Posted April 15, 2006 Report Share Posted April 15, 2006 heyis there anyway I can copy all the tracks from my NW-A1000 to my HD using Connect software?If u cant then is there any other software which can do it?Thanks Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted April 15, 2006 Report Share Posted April 15, 2006 You can`t use those tracks directly copied from A1000 to HD .You will need to use GYM (see software section) Quote Link to comment Share on other sites More sharing options...
