Avrin Posted August 21, 2009 Report Share Posted August 21, 2009 (edited) As it turns out, the crippled MP3 playback "feature" of second-generation Hi-MD units was not created out of thin air. The transformation applied to the signal is not just an arbitrary decrease of higher frequencies. It exactly coincides with the de-emphasis curve provided by the Red Book Standard for audio CDs. And the pre-emphasis/de-emphasis feature, when used properly, can actually increase sound quality by lowering quantization noise in the higher frequency range (which is most affected by it) by 10 dB.Green - white noise with the de-emphasis transformation applied (using SonicStage).Red - an MP3 of pure (flat) white noise played back on the RH10.A practical use for the improperly implemented function follows immediately: if you have a pre-emphasized CD (the first pressing of Pink Floyd's "The Wall" is the most famous example), rip it by a non-deemphasizing program (i.e., not SonicStage or iTunes), compress to MP3 and enjoy perfect sound on a second-generation Hi-MD unit! Edited August 21, 2009 by Avrin Quote Link to comment Share on other sites More sharing options...
