Transfer problems with Sonic Stage
swatty
After a couple of years of happy transfer of field recordings into my library on sonic stage i now find that it wont transfer.
Have recently had computer virus removed and programmes restored. otherwise have not adjusted programs.
Computer works on Windows XP professional
any ideas what might be going on?
can i remove sonic stage and re-load it?
thanks,
swatty
Virus removal and program restoration may be considered a significant change of configuration by SonicStage. And this may cause unpleasant problems.
Do you still have any recordings in your SonicStage library? If yes, immediately run the File Conversion Tool with the Add copy protection box unchecked, to remove DRM from your files, and then copy the files to a safe location. If you have an older version that doesn't allow removing copy protection, then use the Backup Tool to copy files (this method is much less reliable). If you have been recording in PCM only, then you may simply convert all files in your library to WAV format - this is the safest way. ATRAC3[plus] files can also be converted to WAV, but will take much more space after that.
Then uninstall SonicStage/OpenMG/OpenMG Limited Patch, and install this version: http://forums.sonyinsider.com/index.php?showtopic=24405
