SI: Sony’s Attractively Priced CW Series Has Smart Features, Colors, And Windows 7
CW_Series_Blue_Female_Outside
Sony has launched the new CW Series VAIO laptop with Windows 7 due on October 22nd, which is very similar to its existing CS series in terms of price and specifications. There are a few key differences though and I think that this offering will be a strong play for what is Sony’s largest PC lineup in years. The VAIO CW series boasts a lustrous, high-gloss exterior and opens up to a subtle gradient of matching color on the palm rests.
CW_Group1_US
The pricing schemes vary on what model you are looking at, but for the USA here is the plan according to SonyStyle:
cw
As you can see standard specifications start at an Intel Core 2 Duo T6600 (2.2GHz) on a Mobile Intel PM45 Express Chipset (there will be options for a 2.80GHz T9600), 4GB RAM (8GB maximum; PC3-8500), 320GB SATA HDD (500GB available, both at 5400rpm), and HDMI out (1920×1080). There’s also a built in Motion-eye camera and microphone. Pony up a little more and you can get a Blu-ray player/burner and more graphics power.
PIA0001001152
Three USB ports are included, along with a VGA output (2048×1536), and firewire. Estimated Battery Life with Standard Battery (included) – Productivity: Up to 4 hours, DVD Playback: Up to 2.5 hours. Estimated Battery Life with Extended Battery (sold separately) – Productivity: Up to 6 hours, Max. Brightness: Up to 12 hours.
2CW_Glossy_Black_-_Front_Right_with_Open_DVD_lg
The 14.1 inch display is a LED backlit LCD (16×9, 1366×768) powered by a NVIDIA GeForce GT230M GPU with 512MB VRAM or if you prefer to spend a little less a GT210M with 256MB VRAM. The GT230M is a pretty solid graphics card, with is a 40nm chip, DirectX 10.1 and has PhysX, CUDA support amongst other things.
3CW_Red_-_Front_Right_Far_Angle_lg
Connectivity is a breeze with 802.11a/b/g/n Wifi, Bluetooth (2.1, stereo A2DP), up to Gigabit Ethernet, and a HDMI output. There’s also support for Memory Stick DUO, ExpressCard/34, and a SD memory card. Here are some specifications courtesy of SonyStyle:
Untitled-1
Sony has also included one-touch access to the web without the need for the operating system to be on, a feature first found in the VAIO NW series. I’m glad to see Sony extending this feature to more of their laptops, and I think it will be a strong selling point for them.
