SI: Sony Offers Two XDCAM Camcorders With DVCAM Recording, 32GB SxS-1 Memory Card
XDCAM is a tapeless professional video system introduced by Sony in 2003. The latest additions to Sony’s successful XDCAM EX line-up include a shoulder-mount PMW-350 camcorder and a hand-held PMW-EX1R. This new offering combines the exceptional HD imaging performance of XDCAM EX with a number of powerful new features, including standard definition DVCAM recording – a pioneer feature that is available for the very first time to XDCAM EX users.
Designed to widen the appeal of XDCAM EX, the PMW-350 and PMW-EX1R offers leading solid-state performance with industry-wide native workflow via an established network of alliance partners.
PIA0001001213
The PMW-350 draws upon Sony’s award-winning and unrivalled expertise in camcorder design. It uses three 2/3-inch Exmor CMOS sensors with 1920×1080 resolution for full HD imaging. Sensitivity is F12. The camcorder also features DVCAM recording via the CBK-DV01 option and is studio-configurable, with timecode in/out, genlock in, and HD-SDI and HDMI out.
Its design offers the best of both worlds in shoulder-mount technology: a low centre of gravity and light in weight to ensure stability on the shoulder; all while maintaining the familiar operational layout for which Sony camcorders have become renowned for. Another key feature is an ultra-economical power consumption of 15W, thus offering longer operation on a single battery, along with a reduced carbon footprint.
The camcorder will be available in two versions, the PMW-350L, a body-only model and PMW-350K which comes with lens. The lens supplied with the PMW-350K has been developed by Fujinon and offers auto and manual focus with a 16x zoom and a 2/3-inch bayonet mount. Independent focus, zoom and iris rings; auto focus mode; manual focus assist and a focal length of 8 to 128mm (equivalent to 31.5 to 503mm on a 35mm lens) are also key features.
PIA0001001214
The PMW-EX1R is the successor to the PMW-EX1 which was Sony’s first professional file-based camcorder that revolutionised video production when it was launched in 2007. The PMW-EX1R has been improved with a number of new features that have been created as a result of feedback from users. They include DVCAM recording, an HDMI output, a higher-resolution viewfinder as well as one-push Auto Iris.
Like its new shoulder-mount counterpart, the PMW-EX1R features ergonomic enhancements such as an improved hand grip, one-click S&Q mode (Slow and Quick) and easy-to-access switches. Additional benefits of the PMW-EX1R include smooth handle zoom transition, an image inversion option and up to 15 second picture cache recording.
PIA0001001227
The camcorders are not the only new options available to users. Sony is also launching two new media options along with the new PMW-350 and PMW-EX1R. The first is Sony’s new SxS-1 memory card which joins the existing SxS PRO memory media in the line-up.
Developed in response to demand from users for an affordable but high capacity card, the 32GB SxS-1 will feature very high-speed data transfer speed (800Mbps) and high reliability. It provides an average lifetime of five years based on daily use, with life indication displayed in the viewfinder of the new camcorders.
PIA0001001216
The second new option is the MEAD-MS01 adaptor that is meant for use with Sony’s Memory Stick Pro HG Duo HX Series media. Available in capacities from 4GB upwards, this media can be used as either an ‘emergency’ card for production or as a cost effective option for entry-level videographers.
Sony’s current XDCAM EX models, the PMW-EX1 and PMW-EX3 camcorders and PMW-EX30 record deck, will also be compatible with the new SxS-1 and MEAD-MS01 with Memory Stick, through a software upgrade that is set to be available in early 2010.
PIA0001001223
Additionally, users will be able to use the new PXU-MS240 mobile storage unit to transfer data from SxS PRO memory cards to the unit for back-up or off-load of video clips. The unit stores content on a removable hard disk drive (HDD) cartridge like the PXU-HC240 which can store up to 240GB of data.
The software supplied with the new camcorders, Clip Browser, is also being updated to version 2.6. It features a range of new function that includes support for new recording formats and four channels of audio. An additional enhancement also means Clip Browser now automatically detects and corrects “flash bands” that occur in frames as well as a manual mode that allows users to select frames to correct by using a “preview” function.
