SonicStage 3.4 loading one cd after the other
dtrain
Hello,
I've just bought an NW-E503 and love it. This forum has been just as great! I searched the SS FAQ but wasn't able to find out any info about my question so here goes...
Whenever I load a cd into SS3.4 it loads fine, however, when I eject the cd and put in another one SS3.4 doesn't recognize the swap. ie, it shows the track list data from the previous disc. The only way I can get it to kickover is to close the program and relaunch which is time consuming. The refresh feature doesn't do it and the same thing happens when I eject from the program or by pressing the eject button on my Dell PC. This is probably a simple user error, however, I can't figure it out. Any help would be greatly appreciated.
Keep up the excellent work!
Much thanks,
Dtrain
I had the same problem when I first got into MD players, when I bought my MZ-NH1. I tried uninsalling it and re-installing it. No good. I spent a lot of time with it.
Eventually, a good freind of mine suggested to use some uninstall software to completely remove all traces of the program (windows does a really half-a**ed job and leaves lots of registry entrys and strings behind, amongst other things).
So I used advanced uninstaller pro. It worked great for me.
