Using NW-HD3 with Multiple PCs
maggior
With my RH910 (HiMD), I was able to upload music to it from multiple computers with no trouble. I just tried this with my new NW-HD3 and it wouldn't work. It gave me an error indicating that a different rev of Sonic Stage was used to upload the existing music. Which was true - the PC I mainly use I had upgraded to SS3.4, but my other PC was still running 3.3.
Even after upgrading the second PC to 3.4, I still encounter the problem.
Should this work? What might I be doing wrong?
Thanks!
Rich
1 answer to this question
Guest Stuge
This problemis faced by many people.
I will suggest you to install Sonic Stage of Asia Pacific or Japanese or Overseas version on every pc you use but you will need to format your device then you might not get that problem..
Aslo you can easily transfer mp3 from different pc`s without any pronlem using mp3 file manager ver 2.
