Right now on my HD-1, I'm using ATRAC3+ 64kbps......all is fine and well, but when I plug into my stero, I can hear artifacts from recording
Should I redo my player and make all the files 256kbps?
Also, anyone know an easy way to convert to ATRAC? THe proggie from Sony doesn't work with SS 3.4, is there anything I can do to convert to ATRAC w/out SS?
darkangel9685
1 answer to this question
