steveen Posted February 11, 2010 Report Share Posted February 11, 2010 hi. i use a Tascam MD-350. I also recently upgraded software as the unit stuck in 'reading TOC' mode and would not eject disc. Scenario: using headphone output from lap top (mini jack/high quality VDC cable) to x2 phono inputs to mini disc recorder. Recording live radio & play again radio from internet. Lately, recording stops willy nilly...no apparent pattern. No audio output as record mode is defeated.....radio still relaying audio. ssometimes using discs that have been cleared and used again. any ideas?? cheers Quote Link to comment Share on other sites More sharing options...
md user Posted February 17, 2010 Report Share Posted February 17, 2010 hi. i use a Tascam MD-350. ..... No audio output as record mode is defeated ... Explain, record mode is defeated? Sorry, don't know your model, but for general decks I would consider: dirty heads, synchro detect (setting) failure, firmware download corruption, rca lead or connector failure, hardware failure ... and testing on a known deck/portable first. for what it's worth, good luck! mdmad. Quote Link to comment Share on other sites More sharing options...
