The Beep
My band uses a Alesis SR-16 as click track. It is kind of tricky tho...cause when we get to the last chorus I will take my left hand off the keyboard and change tempo. Usually it takes a minute. The bass player suggest that I recorded 5 minutes of the track to an Ipod and then just connect the Ipod to the board and then I could arrange the track into the order in which we perform the set.
Sounds good...only one problem: I don't have an Ipod. What I do have have is a Hi-MD. I know I have one of those connectors to record to the line-in on the unit and I will need an adapter to connect the Alesis. My question is can I eliminate that annoying beeping noise that the MD makes everytime I skip forward or backward amongnst the tracks (or anything else for that matter)?
