NWA1000 Battery packs and Power saving
Crofty
Hi, new to the forum, got a few questions
1) Is the a quick way to turn off the player with it hold on? Ive set the player to the 15s display and turned the brightness right down and am looking for additional ways to prolong the battery life
2) I was rummaging through my old hi fi parts, looking for a compatible remote, and i found some portable sony speakers (originally for md or cd player) and they work with my nwa. They take 4 AA batteries, I was thinking about getting some rechargerables and a charger - Im guessing some chargers and batteries are better than others, any advice?
3) If i was setup with some good rechargeable batterys there must be a way to use them to recharge the nwa's own battery when on the move. So I looked on ebay and found these Pack 1 Pack 2 . The second doesnt say its compatible with the nwa series but ive emailed the seller to find out. What method would you recommend to charge the player with batteries?
thanks, any info is much appreciated
1 answer to this question
Guest Stuge
Welcome to AtracLife !
I don` think anyone here has tried those battery extender packs ..
So you will have to take chance & try it on your own.
