Sony is unveiling the newest addition to its CineAlta line of high-end acquisition systems: the SRW-9000PL camcorder. The new model expands the capabilities of Sony’s previously announced SRW-9000, adding a 35mm imager and PL mount to increase its flexibility and offer shooters more image creation options.
“Demand for digital shooting with a 35mm size sensor is rising for both motion picture and prime-time TV drama productions, two areas where our F35 has had great success,” said Chris Marchitelli, senior manager of CineAlta and Production Systems at Sony Electronics.
“This new model’s S35mm one-chip CCD sensor and PL lens mount are similar to the F35, so it combines the SR portability of the 9000 with the high-end optics of the F35, giving DPs an incredibly powerful and versatile tool for creating any ‘look’ they need.”
The SRW-9000PL offers full RGB image capturing (without color sub-sampling), ultra-wide dynamic range (over 12 T-stops), variable speed (SR Motion) with speed ramp capability, S-Log and HyperGamma capability. The camcorder is capable of 4:2:2 10-bit recording at 1080/23.98PsF, 24PsF, 25PsF, 29.97PsF, and 1080/50i, 59.94i. It can also record 4:2:2 1080/50P as standard configuration. The range of option boards developed for the SRW-9000 (2/3-inch version) can also be used with the SRW-9000PL (S35mm version) for additional performance and functionality.
The HKSR-9001 HD-SDI expansion board adds dual-link HD-SDI outputs and an extra AUX input port, which works as an HD-SDI audio input for providing connectivity to an external audio multiplexing device. This allows users to multiplex up to 12 channels of audio to the HD-SDI input. The latest firmware version of the HKSR-9001 also provides 3G HD-SDI output capability.
The HKSR-9002 picture cache board enables the camcorder to capture and record images with variable speed (SR Motion capability) from 1 to 50 fps. With this board, the camcorder can continuously record up to three seconds of images while the camcorder is in stand-by mode. When the record button is pushed, the stored images are recorded to HDCAM SR tape and the camcorder can continue recording in real time.
With the HKSR-9003 RGB 4:4:4 processing board, the camcorder offers full-bandwidth digital 4:4:4 high-definition RGB recording and output capability. The option also offers S-LOG Gamma, essentially a “digital negative,” allowing users to tailor their images during post-production in the same way they would in a film-based work flow.
Both the SRW-9000 and the SRW-9000PL will be available with an upgrade path to Sony’s next-generation high-speed memory recording system. In addition, Sony will also offer a 35mm upgrade kit (HKSR-90PL) for the SRW-9000 2/3 inch imaging system. The SRW-9000PL camcorder and the HKSR-90PL are planned to be available in the fall, with suggested list pricing of approximately $125,000 and approximately $60,000 respectively.
(press release, pdf)
Related Posts:
