I've got this strange issue with my walkman. For some strange reason my player's OPTIONS button doesn't work. Actually it work, it does the same as BACK button. If you press it once, instead of popping out options menu it goes back to track list (the same as BACK button). Even if you press and hold it, it goes back to home screen instead of turning the device off, as it should do.
It doesn't feel like it is a mechanical malfunction for the buttons feel easy to press and there is no changes in its the way it used to feel when it did work normally. I have tried to restart device by pressing that tiny button on the side, have tried to "Restore Factory Settings" and even format it, nothing helped. Is there anything I'm missing? Is there anything else I coud do to fix it? Thanks in advance.
Konaras
Hello.
Regard, Konaras.
1 answer to this question
