Sony has added three new A-mount lenses to their already robust offering of more than thirty lenses available on the market, perfect for the seasoned or amateur DSLR enthusiast.
The Distagon T* 24mm F2 SSM (SAL24F20Z) functions as a wide-angle 24mm lens on full-frame cameras with 35mm sensors, or as a 36mm equivalent lens ideal for general use on cameras with APS-C sensors. Jointly developed with Carl Zeiss, it features the highly-regarded Carl Zeiss Distagon retro-focus lens configuration designed for wide-angle lenses.
This lens is distinguished by its fast response focus and extremely quiet, very smooth operation thanks to its built-in SSM (Super Sonic wave Motor). It offers a wide and therefore highly versatile focal range from 0.19m to infinity, and features a nine-blade circular aperture that along with the large F2 maximum aperture contributes to smooth, natural bokeh effects.
In keeping with traditional Carl Zeiss design, the all-metal lens barrel has been finished to a very high standard resulting in a visibly high-quality appearance.
The DT 35mm F1.8 SAM (SAL35F18) is part of the ‘Easy Choice’ series, offering photographers at all levels great value, compact and lightweight lenses, the DT 35mm F1.8 SAM (SAL35F18) weighs just 170g. It can be added to a lens kit system and carried without noticeably increasing the weight of the bag.
With an approximately 50mm (35mm equivalent) focal length on an APS-C sensor, this lens is ideal for snapshots and portraits under a wide range of shooting conditions. The high-speed F1.8 maximum aperture is particularly advantageous for hand held shooting in low light.
At just 0.23 metres, the DT 35mm F1.8 SAM (SAL35F18) has the shortest minimum focus in its class, making it an excellent choice for dramatic close-ups too. Whatever the shot, the internal Smooth Autofocus Motor (SAM) drives the focussing group directly and ensures responsive and fluid autofocus operation.
The 85mm F2.8 SAM (SAL85F28) is the first full-frame lens in the ‘Easy Choice’ range, so its launch represents an important development of the line-up as a whole. The 85mm focal length is a standard for portraiture because of the natural perspective that it provides. On an APS-C sensor camera the 85mm F2.8 SAM (SAL85F28) functions as a 127.5mm (35mm equivalent) telephoto lens – and features a Sonnar-type optical design that is considered ideal for mid-range telephoto lenses.
The lens is sharp center to corner, and features smooth defocusing thanks to its large F2.8 maximum aperture and circular aperture design. At 0.6 metres, the minimum focusing distance is the shortest in its class, and SAM motor technology ensures smooth autofocus operation.
The quality optical and mechanical features of the lens mean it is suitable for serious photography and should more than satisfy intermediate to advanced users.
From Sony Europe Press Centre.
