Walkman NW-A1000 Firmware Version 3.00
robby***
Details of the new firmware update:
  Quote
This update program offers the following additional functions:
- Playing back with AAC format* is available without any format change.
Therefore, AAC format files in SonicStage CP can be transferred without converting them to ATRAC format.
- The Artist Link Shuffle mode is added to the Intelligent Shuffle.
- The clock display and calendar display functions are added.
If CONNECT Player or SonicStage CP is used, the unit clock synchronizes to the computer when the Network Walkman is connected to the software.
- The screen saver is selectable.
- Group +/- can be operated using the compatible stick controller (RM-MC35ELK).
Playback can be adjusted to the beginning of the first track in the previous or next group from the current group, irregardless of the starting position or the playmode.
It is also possible to move to the first track of the group in Playlist, Bookmark, Trash Bin and Favorite 100.
* Below are the specifications of the AAC file which can be played back with the Network Walkman
- AAC (Advanced Audio Coding)
- Sampling frequency: 11.025/12/16/22.05/24/32/44.1/48kHz
- Bit rate: 16 - 320 kbps, VBR (Variable Bit Rate) is supported.
Copyright protected AAC files cannot be played back.
It is not guaranteed that all of AAC files can be played back even if the above conditions are met.
The following functions are modified in this update version:
- The sorting order is based on the album track number rather than alphabetical order when Artist ALL is selected from the Artist tree of the List search.
- The animation design which appears while the HDD is accessed is changed.
- The resume track information reset is prohibited with the recharge operation.
P.S. I love this site, found it very useful over the last few months
3 answers to this question
Wow, Sony NW is supporting AAC? That is almost unreal, although not entirely impossible considering the PSP has supported AAC for quite some time. Let's see if Sony can make AAC gapless in the walkman (AAC can be gapless, but stupid Apple doesn't care).
