stahlhelm Posted September 2, 2010 Report Share Posted September 2, 2010 Hi, I am just wondering what kind of USB cable is needed between an NetMD Walkman and a PC. The PC end is no quiestion but what about the walkman end? Thank you Regards Quote Link to comment Share on other sites More sharing options...
Azureal Posted September 2, 2010 Report Share Posted September 2, 2010 It depends on the MD unit, some use the standard mini USB connector on the MD side, others use a special proprietary connector. What model MD are you referring to? It is likely that someone will know what cable is required. Sometimes that sort of information is listed in the MD browser: MiniDisc Equipment Browser Quote Link to comment Share on other sites More sharing options...
stahlhelm Posted September 3, 2010 Author Report Share Posted September 3, 2010 It depends on the MD unit, some use the standard mini USB connector on the MD side, others use a special proprietary connector. What model MD are you referring to? It is likely that someone will know what cable is required. Sometimes that sort of information is listed in the MD browser: MiniDisc Equipment Browser It is the MZ-NF810 walkman. Thank you Quote Link to comment Share on other sites More sharing options...
Azureal Posted September 3, 2010 Report Share Posted September 3, 2010 I think the 810 uses a standard mini USB connection on the MD side of things. You can pick one up for a couple of dollars. I have about 30 of them in various drawers around the house! Quote Link to comment Share on other sites More sharing options...
