Transfer contents of discs from MDS-JE330 to PC/iPod
You'll have to play the discs on the JE330 and record the output via the input on your sound card. According to the MD Browser, the JE330 has no optical output so your only option is to record via the line level output on the deck and into a comparable line level input (read: NOT microphone input) on your PC sound card.
Many folks around here and elsewhere use the freely available recording application "Audacity", just Google it, download it and start recording.
You'll have to break the one large recording up into multiple smaller tracks after recording, or you can just import the single large file right into iTunes.
