HACK MZ-RH10 Volume and Eq
Ihave old mz-rh10 european version. i don't reach custom eq settings and it has volume cap. i search all along forum, but most of links were BROKEN! Can anybody help me? it can be pined to page later...
I SOLVED IT. HERE THE SOLUTION. IF SOMEONE NEED IT, I WRITE DOWN.
1 OPEN THE DEVICE
2 SET "HOLD DOWN"
3 >> >> << << << >> >> << PAUSE PAUSE (WHILE PRESSING "MENU" BUTTON)
4 THEN RELEASE pressing MENU. (but hold on must be still on! )
5 press volume + and manual appears
8 press >> 5 times until you'll see 0113
9 then again press volume + and then you can contol "vol +" and "vol -" button to select number 24 (which are last numbers of HEX on the screen)
10 FIND NUMBER: 24
11 Press "PAUSE" 1 time
12 Press "STOP" 4 times
Battery out.
DONE. There are no volume cap now and you can change eq setting freely.
