ssasha Posted June 29, 2006 Report Share Posted June 29, 2006 I use max bitrate of atrac, max volume, min brightnesslife - about 13 hrand when i use line output life seems to be shorter Quote Link to comment Share on other sites More sharing options...
0 VieloAiposh Posted June 29, 2006 Report Share Posted June 29, 2006 when you say 13 hours.....do you mean that after 13 horus it does actually shut off because the battery is dead? or do you mean that its on the last bar, so you charge it?i find that my player goes to the last bar of battery life fairly quickly.......but stays there for a very long time.if you didnt let it run all the way down, try that, because as i said, beign on the last bar of battery life doesnt neccessarily mean that its out of juice.-x-x-x- Quote Link to comment Share on other sites More sharing options...
0 ssasha Posted June 30, 2006 Author Report Share Posted June 30, 2006 13 hours to shut off Quote Link to comment Share on other sites More sharing options...
0 VieloAiposh Posted June 30, 2006 Report Share Posted June 30, 2006 well the 35 hours stated is based i think on the lowest bitrate of atrac, mid volume, etc etc.also, do you use any of the EQ settings.....i find that makes a HUGE difference.anyways i use min brightness, max vol, 64kbps atrac, no screensaver, etc, and i get around 25 or more hours, depending on usage.there are so many factors involved.....play mode, the ammo8unt of time you sepond swithcing between tracks, and pressing buttons on the player.13 hours does seem kidna short though......but maybe try a lower bitrate ir something?-x-x-x- Quote Link to comment Share on other sites More sharing options...
0 ssasha Posted July 1, 2006 Author Report Share Posted July 1, 2006 i like hi bitrates, no eqand seems 13 hr it is not so poorits just expirience of "player's life" Quote Link to comment Share on other sites More sharing options...
0 chriswyatt Posted July 4, 2006 Report Share Posted July 4, 2006 When Sony came up with 35 hours they probably were using 48 Kbps with the volume set to 0, wouldn't surprise me. Quote Link to comment Share on other sites More sharing options...
ssasha
life - about 13 hr
5 answers to this question
