Bad_Guy Posted July 4, 2006 Report Share Posted July 4, 2006 Hello,I got a problem with my NW-A3000 since this morning.I've just noticed that my player is very hot !!All buttons are lit but commands do not respond Each time I press any button, nothing happen...I dont really know what to do ?Does anyone here got this kind of problem ?Maybe I should try a reset ?Thank you Quote Link to comment Share on other sites More sharing options...
0 dragulagu Posted July 4, 2006 Report Share Posted July 4, 2006 (edited) Hello,I got a problem with my NW-A3000 since this morning.I've just noticed that my player is very hot !!All buttons are lit but commands do not respond Each time I press any button, nothing happen...I dont really know what to do ?Does anyone here got this kind of problem ?Maybe I should try a reset ?Thank youIf you still have a warranty for your player then bring it asap, else let it be repared in a shop.The overheating comes from too much amperes trough a component in your player (thanks to a brokenresistor or faulty diode). Anyway, don't use the player now, because when you let it on, itll get overheated and itwill damage itself. Just bring it in en let it be repared, thats the best advice I can give you (repairing it yourselfis hard, because you don't have the blueprints for that model ). Edited July 4, 2006 by dragulagu Quote Link to comment Share on other sites More sharing options...
0 Bad_Guy Posted July 4, 2006 Author Report Share Posted July 4, 2006 I read the FAQ and push reset button.Now it works fine, so cool Quote Link to comment Share on other sites More sharing options...
0 dragulagu Posted July 4, 2006 Report Share Posted July 4, 2006 I read the FAQ and push reset button.Now it works fine, so cool It's such a good thing with sonys that what the software lacks in stability, the hardware has in robustness Quote Link to comment Share on other sites More sharing options...
Bad_Guy
Hello,
Thank you
3 answers to this question
