MAMcGhee Posted August 21, 2012 Report Share Posted August 21, 2012 Sony Vaio upgrade from vista to win 7 Sorry if this is not the correct section to post this. I have a Sony Vaio model:VGNAR320E I upgraded it from Vista home 64bit to Win 7 Ultimate 64bit. It works fine for a few days and then all of a sudden it stops booting up or goes into a boot loop at the sony vaio startup screen. I run the win 7 repair disk and choose the option to fix startup issues. When done I reboot and the computer works fine for a few days then repeats the same issue. Suddenly stops booting up. I tried a different hard drive and the same issue occurs stops booting or goes into a boot loop at the sony vaio startup screen. Processor Type: Intel®Core™ 2 Duo Processor T5500 Speed: 1.66GHz1 Front Side Bus Speed: 667MHz L2 Cache: 2MB Advanced Smart Cache Technology: Intel®Centrino®Duo Mobile Technology Memory Type: DDR2 SDRAM Installed: 2GB (1GBx2) PC2-5300 Maximum: 2GB Speed: 667MHz Hard Drive Capacity: 160GB2 Speed: 4200rpm Interface: Serial ATA Please advise, any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
MAMcGhee
Processor
Speed: 1.66GHz1
Memory
Type: DDR2 SDRAM
Maximum: 2GB
Speed: 667MHz
Hard Drive
Capacity: 160GB2
Speed: 4200rpm
