grenert Posted July 6, 2006 Report Share Posted July 6, 2006 I tried importing a bunch of WAV files into SonicStage 3.4. They appeared in my library, which is fine. However, they were still WAV files. Is there a way to automatically convert to ATRAC upon importing into your library? I can only get the file to convert when transferring to an ATRAC device, and even then, they are still WAV files on the computer.It seems like this should be possible, but I can't figure it out. Thanks for any help.-J. P. Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted July 6, 2006 Report Share Posted July 6, 2006 You ca convert wav files 1.IN my Library of SonicStage --> Right Click --then select Convert Also Upgrade your SonicStage ver3.4 to SonicStage CP 4 Quote Link to comment Share on other sites More sharing options...
Avrin Posted July 7, 2006 Report Share Posted July 7, 2006 Select a whole album, then right click and Convert, if you want it to be gapless. Quote Link to comment Share on other sites More sharing options...
grenert Posted July 10, 2006 Author Report Share Posted July 10, 2006 Thanks for your replies; this is exactly what I was looking for! Quote Link to comment Share on other sites More sharing options...
