Microswitch MD searching
enito
The only source for the specific part I know of is another drive unit from a faulty machine. As I think I said in another thread, you could do with getting hold of a scrap unit, especially as you may need a replacement write head too. Plenty to be found on eBay, just make sure the seller confirms they have not been in and attempted to repair.
Jim
PS - if physically broken, replace of course. But if just bad contacts, try some spray switch cleaner first.
  • 1 month later...
Hi, thx for the reply, i appreciate!!
here the photos, you can see good one switch and the other broken, if you need more specific, let me know ;)
http://postimage.org/image/c8thjscd3/
http://postimage.org/image/4u45reqhj/
http://postimage.org/image/nnpyoeopj/
http://postimage.org/image/ora30d9cn/
Greets
Hi again Enito
I have just scrapped an MDM-3B drive unit for the parts, so I have a surplus switch board if you would like to purchase it. That way you can remove the switch you need and have a couple of spares for the future. I believe this only has one fault - the chuck-in switch S685 seems to stick and the contacts may be bad, resulting in no disc load when a disc is inserted in the drive.
You can have it for the cost of posting to you, plus a few GBP to cover my time and effort. Where in the World are you?
Jim
I found only a similar switch:
ALPS SPVR110100 http://uk.mouser.com/ProductDetail/ALPS/SPVR110100/?qs=sGAEpiMZZMsT%2fJC6Zg5iLMggxk458NAyDwkhynBIPMI%3d
ALPS SPVR120100 http://uk.mouser.com/ProductDetail/ALPS/SPVR120100/?qs=sGAEpiMZZMsT%2fJC6Zg5iLMggxk458NAyM8KXYyWQLUA%3d
Panasonic ESE13V01A http://uk.farnell.com/panasonic/ese13v01a/switch-detect-spst-no/dp/2079637?Ntt=ESE13V01A
ALPS SPVM110100 http://uk.mouser.com/ProductDetail/ALPS/SPVM110100/?qs=sGAEpiMZZMsT%2fJC6Zg5iLJMl1JxwrxfcLqLaTD4njLc%3d
Panasonic ESE-16J001 http://www.newark.com/panasonic/ese-16j001/switch-detector-spst-no-250mn-10ma/dp/83T2677
Multicomp MCATE-1-V http://www.newark.com/multicomp/mcate-1-v/switch-detector-spst-1ma-40gf/dp/31M5577
Multicomp MCATE-2-V http://www.newark.com/multicomp/mcate-2-v/switch-detector-spst-1ma-40gf/dp/31M5578
Regards,
Maciek
I really i appreciate your help, !!!! thx a lot!!
Hi again Enito
Jim
Hi, thx for reply, ...sound goood, let me know price ;) heh im from Chile (SouthAmerica)
Greets!
