Best way to get MD bits into a Mac
Hello everybody,
I want to convert my minidisc recordings to a iMac with OS X 10.9.3. What I've been doing is connecting the line out from my MZ-R2 to the line ins on my audio interface, and then using Logic Pro to import the music in .AIFF format (or .wav).
I'd like to know if there is a better way. For instance, if I buy a MD player with optical out, can I connect it to ADAT or S/PDIF inputs? Do I need to convert the data? Is it worth the while?
Does it make sense to use the line out to line in connection mentioned above and then setting a 192Khz sampling rate on Logic to get maximum audio quality?
Any suggestions would be most welcome.
Thank you
