MZ-1 Battery replacement
Sphig
More for the scrappad - the venerable MZ-1.
The original BP-1 batteries are mostly deceased now and had limited capability.
One rough and ready solution is to acquire a couple of lithium rechargeables type 14650 and an appropriate charger (available on ebay for around £10/$15/15euro the lot).
Find some high density polystyrene and use a hobby knife to cut out three blocks (two for shimming and one to hold the home made end connector). Double sided tape will hold the shims in place.
Fashion an end connector to sit in the battery doorway and provide contact/pressure - a couple of brass paper fasteners will do as well as anything.(Push them through the polystyrene and join them together at the rear)
The result - a functioning portable player with no damage or modification.
Lithium batteries need special care over charging - so a word of warning - Never plug in the MZ-1 charger while lithium batteries are inserted - it can be a dangerous thing to do. Never short the batteries and always check polarity when inserting.
Pictures should be self explanatory. Enjoy the resurrection of the dinosaur!
  • Like 1
