nino Posted August 18, 2006 Report Share Posted August 18, 2006 I get the feeling im being extremely thick and missing something out but is it posssible to add multiple albums to to the now playing list?ie: i have metallica S&M disk 1 and 2 and i play 1 and 2 together in the same list.The only way i can see being able to do this is to add the 2 albums to a playlist and play the playlist which is a bit long winded!cheersNino Quote Link to comment Share on other sites More sharing options...
0 granbajo Posted August 20, 2006 Report Share Posted August 20, 2006 I can't remember at which level do you have to do this (either when you are viewing groups or the albums for a group) so then you press "Option" to open the menu, and you can select play from there Quote Link to comment Share on other sites More sharing options...
0 b0ng0 Posted August 21, 2006 Report Share Posted August 21, 2006 I would say maybe go to album view.... but maybe not. Play all songs by artist then just start from the first SnM track so it plays through both cd's?I have this album on mine, i'll try it later, see if I can find a way to do it. Quote Link to comment Share on other sites More sharing options...
0 memoland Posted August 23, 2006 Report Share Posted August 23, 2006 you can also change both disc 1 and 2's album name as the same, like just "S&M", from the file properties. you must do this process for each track and upload nw a3000 again. now you can see "S&M" as a sub-title of albüm under metallica . Quote Link to comment Share on other sites More sharing options...
nino
cheers
Nino
3 answers to this question
