Avonne Posted August 21, 2006 Report Share Posted August 21, 2006 Hi, I'm here because I have a problem.When I click on the SonicStage icon I get this It says my database has changed due to a systen change and needs to be authenticatedThen I get this 'Click ok to close sonicstage and launch system information restore tool.Then I get this This one says it cannot connect to internet.Its a BB connection, on all of the time.and thats it, the programme will not launch. Any ideas welcome. Quote Link to comment Share on other sites More sharing options...
0 Costas0 Posted August 21, 2006 Report Share Posted August 21, 2006 Me too! I posted the same problem in the software forum, but I thought it might be down to me using Windows Vista Beta 2, but it seems that you're using XP...hmm... Haven't managed to find a solution yet but will keep trying!not much help - lol! Quote Link to comment Share on other sites More sharing options...
0 peterjf Posted August 22, 2006 Report Share Posted August 22, 2006 If you have got a backup of your music library, have you tried using the SS backup tool to restore it?I think the utility in the screenshots only runs when your library is corrupted (and no, I could not get it to work either, but a database restore solved the problem I was having at the time). Quote Link to comment Share on other sites More sharing options...
0 maxjensen Posted September 1, 2006 Report Share Posted September 1, 2006 I don't get why Sony is offering SSCP 4 instead of Connect now. Connect is a piece of crap. But SSCP is even worse, I think. When I transfer songs to my A3000 it doesn't refresh so I have to close it and reopne the program.Also, it crashes more often than it works. I'm just happy Connect works on my machine otherwise my A3000 would have been useless. Wish the MP3 File Manager for the flash-based players would work for A3000 too. Quote Link to comment Share on other sites More sharing options...
Avonne
Then I get this
Then I get this
Any ideas welcome.
3 answers to this question
