Based on the model that I listed above is there a way to do the following:
1. Upgrade the CPU from a I7Core; to a faster one? Is the CPU soldered to the motherboard? I went to the official Sony Forums and a moderator finally just told me that they don't recommend updating the CPU.
2. Memory Upgrade: Is it possible on this laptop? I have 12 gigabytes installed now.
3. Is their a way to Force Windows 10 Pro to use only the Dedicated Nvidia 735M Graphics? I played in the Bios and think I disabled the Onboard Chipset Intel HD 4000 graphics. Also I went to device mgr and disabled the Intel Graphics under Display Adapters. It flashes, loads the Basic Windows VGA Driver from 2006, I believe.
Wingcmdr77
3 questions:
