Minidisc to imac ?
Philspain
Your options are limited. Some people run a Windows VM on their Mac and have reported success running Sonic Stage that way. Perhaps you could do a line-in to the iMac and use Garage Band or something similar? When I needed to get MD onto my iMac, I copied the MDs digitally to CD-RW using a standalone CD-R and then imported to iTunes. There is no software that will run on current Macs natively that will do what you want. However...
You may want to consider trying this unofficial workaround, specifically for Mac:
https://github.com/gavinbenda/platinum-md?fbclid=IwAR0SZNDAlmajn0hvMxj5rFWS3WxL--nK3KroSAZO6Q01pzYxkRMQhmYI7Cg
https://github.com/gavinbenda/platinum-md?fbclid=IwAR06CZKaqM9dlft7PNBj_RzUkGBn9fPD2G2DTq_ZRllqIcpc84tWBllqeZ8
Initial reports of it have yielded about what you'd expect for an Alpha-like release.
