psp-maniac94 Posted September 15, 2006 Report Share Posted September 15, 2006 I have once installed Sonicstage on my computer. I downloaded Stardock Windows blinds, and my sonicstage wasnt working. I uninstalled and re-installed sonicstage, getting an error after each doble click stating., Application failed to initialize(144). i uninstalled stardock via add remove programs. Deleted any folder with the name stardock on it, and deleted the registery key. i try to install SS, and i still get an error after each doble click stating., Application failed to initialize(144). Please help;( Quote Link to comment Share on other sites More sharing options...
chatoyer Posted September 15, 2006 Report Share Posted September 15, 2006 Not fun. I've heard SS doesn't play well with those kinds of applications. Your best bet is to do a system restore back to before you installed SS (and thus before you installed Window blinds or whatever it is). If that doesn't work, not sure what else to do... Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted September 15, 2006 Report Share Posted September 15, 2006 I have once installed Sonicstage on my computer. I downloaded Stardock Windows blinds, and my sonicstage wasnt working. I uninstalled and re-installed sonicstage, getting an error after each doble click stating., Application failed to initialize(144). i uninstalled stardock via add remove programs. Deleted any folder with the name stardock on it, and deleted the registery key. i try to install SS, and i still get an error after each doble click stating., Application failed to initialize(144). Please help;(Welcome to ATRACLife!As mentioned by chatoyer, some desktop customizing utilities (such as WindowBlinds) are known to be in conflict with SonicStage. Disable the utilities in question or install those that are not in conflict (example: StyleXP) with SonicStage accordingly. Quote Link to comment Share on other sites More sharing options...
psp-maniac94 Posted September 15, 2006 Author Report Share Posted September 15, 2006 I have, thats my problem. i also tryed system restore, and it doesnt go back that far Quote Link to comment Share on other sites More sharing options...
f1rick Posted September 15, 2006 Report Share Posted September 15, 2006 Try this, it might help.Navigate to:C:\Program Files\Sony\SonicStageright click on "Omgjbox.exe" and select properties. Click on compatibility and select disable visual themes.can resolve similair problems. Quote Link to comment Share on other sites More sharing options...
psp-maniac94 Posted September 16, 2006 Author Report Share Posted September 16, 2006 i deleted All Sony folders. so now i have no idea. I removed sonicstage from add/remove also Quote Link to comment Share on other sites More sharing options...
chatoyer Posted September 17, 2006 Report Share Posted September 17, 2006 If the suggestions here don't help, I would probably go with a system re-build. I know that may be a bit overkill, and for me this can literally take days before I get everything back to the way it was, but look at it is an opportunity to flush everything out with a clean install. Maybe wait a few more days to see if any others post suggestions/tips in this thread, though, just in case. Good luck! Do let us know how it works out for you. Quote Link to comment Share on other sites More sharing options...
psp-maniac94 Posted September 22, 2006 Author Report Share Posted September 22, 2006 I would, but i have certain software i cant get back if i system re-build. What should i do? Quote Link to comment Share on other sites More sharing options...
chatoyer Posted September 25, 2006 Report Share Posted September 25, 2006 I would, but i have certain software i cant get back if i system re-build. What should i do?Well, that becomes a problem. It becomes a toss-up: SS to work well and lose programs, or keep programs and have trouble with SS. Quote Link to comment Share on other sites More sharing options...
