alisam Posted September 21, 2006 Report Share Posted September 21, 2006 Very new to MP3 players and have a NW-E005F. I have been using SonicStage 4 but came across VoidMP3FM which I downloaded last night. (20 September 2006)As per some of the previous comments I also get messages of Unknown and NO ITEM when viewing Songs and Albums.My question is, has the issue (NO ITEM/Unknown) been fixed or is it outstanding. If fixed, then am I doing something wrong. I have all my Computer folders named as:ARTIST - ALBUMand simply dragged each folder onto the MP3 player.Everything seems to work OK so far. Quote Link to comment Share on other sites More sharing options...
maskao Posted September 21, 2006 Report Share Posted September 21, 2006 Are your files ID3 tagged? Cause the player takes the information from this tags, not from the name of the file Quote Link to comment Share on other sites More sharing options...
alisam Posted September 24, 2006 Author Report Share Posted September 24, 2006 Are your files ID3 tagged? Cause the player takes the information from this tags, not from the name of the fileI started from scratch and formatted the player. Installed the s/w into the root directory and then checked the ID3 tags via Mp3-Tag Studio 3 (I'm no expert on the tags buy they seemed to be correct). I then copied the 1 album to the player but still have the same problem when trying to search for a song/album/artist in the Search function.Note: The correct track name is displayed when the player is playing the song. Quote Link to comment Share on other sites More sharing options...
masa Posted September 24, 2006 Report Share Posted September 24, 2006 Yeah, i dont think the search folder works. I have the same prolem. i think you have to live with that for now.Yeah, i dont think the search folder works. I have the same prolem. i think you have to live with that for now. Quote Link to comment Share on other sites More sharing options...
NW-E003F Posted September 27, 2006 Report Share Posted September 27, 2006 Yeah, got the same problem, would be really nice to have the search option.I have the NW-E003 ver. 2 firmware, and since the Bug list in Void's website is not really there, i'd like to note aother bug (not suggestions\improvements) i've found:The time progress in the device is slow, i.e. 1 minute in the NW is almost 2 minutes in real life. The songs are played fine, it's just the time display that is screwed up.But other than that, it's doing its job. really nice!BTW - any chance of making it an open source so we could all try and help? Quote Link to comment Share on other sites More sharing options...
