14mm x 1.2mm (Square), 43mm circumference Drive Belt
Charlie Linx Audio
Hi All,
I have supplied belts for several years now, and have been asked for this size frequently. It is now almost impossible to get.....so I have got 100 of these made and will have them available by about 20th November......they are more expensive than my usual stock as the production cost is a one-off, but can supply them at £2.45 each plus postage.
The belt is good quality, measures 14mm external diameter, is 1.2mm x 1.2mm square cross-section, and has a 43mm circumference
If you are interested then please let me know by message so your details are keptb private.
All the very best - enjoy lockdown if you are suffering it as we are here in the UK!!!!
Charlie
