Write protect switch
Hi Colin,
Welcome!
When you say "faulty" how have you determined this? Is the "pin" broken off? (Usually you will be able to see a short blue and a short white pin, one being the write protect detect and the other being the MD-MO/MD-CD detect - based on pits in the MD disc case).
Realistically we've found the most practical way to solve all drive issues, is to swap the drive from a donor machine - if you're sure the switch is not repairable (i.e. not just sticky/dirty). It's unlikely you'll find a replacement part - it's not a standard off-the-shelf part unfortunately.
Kevin
