DrWebster Posted April 10, 2021 Report Share Posted April 10, 2021 Having an interesting problem with my MZ-1. If I try to insert a disc, the display will show "Loading" but the mechanism won't try to pull the disc in. The motor doesn't seem to be engaging at all, but clearly the unit can tell that a disc is trying to be inserted. I'm not seeing much online about this being a common problem, and looking through the service manual, disassembling this model seems quite involved. Has anyone encountered this problem before? Is there a recommended repair shop in the US who could fix this? (I'm aware that there are other, better MD portables that I could use instead -- I'm a bit of a collector, so I'd like to have this one working again, especially since it's in perfect cosmetic shape.) Quote Link to comment Share on other sites More sharing options...
Auster-V Posted May 5, 2021 Report Share Posted May 5, 2021 Taking the top cover off is not that difficult. only 6 screws and a bit off wiggling. After that connect the power and insert a disc. Quote Link to comment Share on other sites More sharing options...
