Omgjbox.exe error
Pietro
Hi, I face a big problem with my sony walkman: I downloaded the SonycStage 4.2 from the official site (Sony) and at the end of a regular installation it doesn't works.
I face an error message:Omgjbox.exe has caused an error and must be closed by windows.
I already removed and reistalled it several times but nothing change.
I try to use it on a Packard Bell EasyNote with Windows XP HE (latest update).
Anybody can help me?
Thanks in advance.
:sad:
Welcome to ATRACLife!
Some desktop customizing utilities (such as WindowBlinds) are known to be in conflict with SonicStage (i.e. error message: "Omgjbox.exe has caused an error and must be closed by windows"). If you have one of those desktop customizing utilities, you will need to uninstall the software in question or install those that are not in conflict (e.g. StyleXP) with SonicStage.
If the problem still persists, you may need to reinstall SonicStage CP 4.2 as outlined within our SonicStage Software FAQ. Note: it would be advisable to utilize a registry cleaner such as CCleaner to properly clean out any remnants SonicStage registry within your sytem prior to a reinstallation of SonicStage.
