I have a good idea! please help!
nyolcvan
(my englis is bad, but I hope so, you will understand it)
I have a good idea, how "the music upload to player" become easier:
1. you need copy mp3s to player with windows explorer or total commander
2. only need you run a *.bat file (the bat file will rename *.mp3 to *.oma, and make *.dat file, etc..)
3. that's all
try it:
run notepad:
insert in it:
rename "*.mp3" "*.oma"
save as rename.bat
if you run raname.bat, it will rename all *.mp3 to *.oma in the same directory
but this bat file isn's working, because the sony's atrac3 structure is complexier.
I'm not a programmer, so I can't write the good bat file
Can somebody write the correct bat file, please?
(somebody are know, how build the sony structure...)
it is important for me..
I think this method is easy and comfortable
Edited by nyolcvan
