Can't listen to music on my E005 & stereo
britpjr
If I copy music onto my Sony Walkman NW-E005 using the Sony software I can listen to it on the device but can't play it on my stereo. If I copy music using other software in MP3 fromat I can listen to it on my stereo but not on the device itself using the headphones.
Any suggestions as to what I should do without having to have two versions of the same track on the MP3 player? :huh:
How do you connect your E005 to your stereo? Via USB? If so, make sure you only use MP3 for the tracks since that is the most commonly supported format. Also, you need to transfer the MP3s using sonicstage in order for them to be playable on the E005. Refer to the manual of your stereo to see if it can support foldered/nested folder file structure or not. If you connect via the analog headphone out, there should not be any problem since the E005 is doing the decoding.
I never use voidmp3fm, but I think it will create the same folder structure like Sonicstage for the MP3s to be playable on the E005 itself. If your TEAC cannot support nested folders, then you're out of luck other than connecting the player via analog headphone out.
