ml_sony causes problems with winamp 5.32
urbanite
Hi,
After installing the ml_sony.dll plugin for winamp, the Format Converter feature of winamp v5.32 does not work. But if I remove the dll the feature works again. Just thought I should point this issue out.
Also I can't seem to transfer .acc files to my player with the plugin, not quite sure if this is a problem with the plugin or something else.
Thanks
