saleh Posted January 12, 2007 Report Share Posted January 12, 2007 every time i start gym i get this errorSee the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.************** Exception Text **************System.ArgumentOutOfRangeException: startIndex cannot be larger than length of string.Parameter name: startIndex at System.String.InternalSubStringWithChecks(Int32 startIndex, Int32 length, Boolean fAlwaysCopy) at GYM.Classes.AllTracks.ReadTrackTag(BinaryReader r) at GYM.Classes.AllTracks.ReadTracks(String sourceFilename, String sourcePictDb) at GYM.Classes.AllTracks..ctor(String driveLetter, Boolean displayCover) at GYM.MainForm.Form1_Load(Object sender, EventArgs e) at System.Windows.Forms.Form.OnLoad(EventArgs e) at System.Windows.Forms.Form.OnCreateControl() at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.WmShowWindow(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.Form.WmShowWindow(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at GYM.MainForm.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)************** Loaded Assemblies **************mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll----------------------------------------GYM Assembly Version: 1.0.2198.34693 Win32 Version: 1.0.2198.34693 CodeBase: file:///F:/GYMv1.2beta/GYM.exe----------------------------------------System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll----------------------------------------System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll----------------------------------------System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll----------------------------------------System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll----------------------------------------Interop.QuartzTypeLib Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///F:/GYMv1.2beta/Interop.QuartzTypeLib.DLL----------------------------------------CSSound Assembly Version: 1.0.2198.34692 Win32 Version: 1.0.2198.34692 CodeBase: file:///F:/GYMv1.2beta/CSSound.DLL----------------------------------------************** JIT Debugging **************To enable just-in-time (JIT) debugging, the .config file for thisapplication or computer (machine.config) must have thejitDebugging value set in the system.windows.forms section.The application must also be compiled with debuggingenabled.For example:<configuration> <system.windows.forms jitDebugging="true" /></configuration>When JIT debugging is enabled, any unhandled exceptionwill be sent to the JIT debugger registered on the computerrather than be handled by this dialog box. Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted January 13, 2007 Report Share Posted January 13, 2007 Welcome to AtracLife!Which Version of Net Framework are you using ?Also ,On Which Network walklman are you trying to use GYM? Quote Link to comment Share on other sites More sharing options...
saleh Posted January 15, 2007 Author Report Share Posted January 15, 2007 I am using .Net 2.0 and the device i am using is a NW-A3000 Quote Link to comment Share on other sites More sharing options...
