importing songs (without using sonicstage)
destroyofmonsterswhat
1 answer to this question
hey. i'm having trouble importing songs on my new nw-s205f player. i've tried using the sonicstage program, but the only songs i can listen to on the player is the default ones that came on it. how the hell do i make it work. and is it possibly to import songs manually??
have you tried plugging it in and under the transfer tab at the top/ the left side of the blue bar select your mp3 player
highlight the albums you want to transfer and click the arrow button between the two boxes.
if that did not work your mp3 player might be broken and need replacing. I know someone who is having this problem with an ipod nano which they are exhanging
