Problem importing songs to SS4.x
wai_lai416
occasionally i get Cannot find music file that are not registered to Sonicstage error code:00007180 What does that mean? and is there anyway of fixing it? and as for the titling songs in chinese for the id3 tags ~ is there a way to make it display chinese even though my system's unicode is already changed to chinese? i tried changing the registry and running appolache and it said my system is already set to display the selected unicode so no change is made?
You also get this problem if the folder you are trying to import from is sitting in the "My Library" location used by SS. The Golden Rule (mentioned I believe in the SS FAQ in this forum) is to always place folders to be imported from someplace else, or SS will *always* give the exact error you mention!
Hope this helps...
